tom_rob_89 10 Posted April 9, 2013 Hi all I need to change my pads and discs but just wondering if its right that it has grooved discs on the back and smooth discs on the front? Cheers Tom Quote Share this post Link to post Share on other sites
leon263 0 Posted April 9, 2013 Pretty sure the grooved discs have been added at some stage by a previous owner. I've had four Corrados and they all had standard discs all round. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted April 9, 2013 Stick with standard rather than grooved. Quote Share this post Link to post Share on other sites
Johnboy Corrado 10 Posted April 9, 2013 Stick with standard rather than grooved. No Corrado's came with grooved discs. They would have been put on by previous owner. Unless you are running over 200bhp standard discs will be good enough. Just remember when you fit new discs and pads they will need to bed themselves in so drive bit more carefully and start braking a bit earlier than normal Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 9, 2013 Prob worth changing the bearings on the rear too.. you'll have to put a race in the new discs anyway, may as well make a new one and whilst youre at it put a new bearing on too. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted April 10, 2013 As Gaz says, fit new bearings, genuine VAG ones are worth paying a bit extra for. Don't over-tighten the retaining nut or they will wear out very quickly. Don't forget to swap the ABS cages over to the new discs (sounds obvious but is easily forgotten.............). Best wishes RB Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 10, 2013 Good point about the ABS Cage... ive had to fish old discs out of the bin before to get the cages off. That was AFTER id refitted all the disc etc and realised the ABS light coming on. :lol: You can imagine the swearing of having to take it all apart again haha. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 10, 2013 Best to buy new cages... I know Eurocarparts do 'ABS' discs where the cages come already on them but not sure these are that cost effective as the cages are not expensive from VW Quote Share this post Link to post Share on other sites
tom_rob_89 10 Posted April 11, 2013 Thanks for all your reply's guys. All very helpful :) Cheers Tom Quote Share this post Link to post Share on other sites
