aide
vr6 coil & dizzy/ hall sender.
tracing a non starting fault and cant find parts local, need;
- known good coil
- mines an early vr, so known working dizzy and hall sender
now need help with this one - ive searched but cant get definite answer on whether a dizzy vr has a crank position sensor, figure i may as well get a known working cps to test if they do????
cheers.
I have a coil on my 94 Vr6 that i'm reluctantly currently breaking for spares. Not sure if this would be the same as an earlier Vr?.
I would also have the other bit but not sure what it is so if your interested then maybe you could send me a pic or describe to me what it looks like & it's location.
i'm guessing the coil would be the same same, how much you want posted?
if yours is a later vr it would be coilpack distribution and not dizzy.
Mine is a later Vr,94. Make me an offer & we can go from there
been doing a bit of reading, understand the dizzy and coilpack coils are in fact different, something to do with how they're triggered. have to give it a miss i'm afraid.
still on lookout for a dizzy coil for testing...
if ti falls thru with robrado974 i have a 92 vr we are removing the dizzy setup for obd2 setup so let me know if you need anything
Yes Rob thanks, pm me your PayPal.
Cheers Alex, i might get back in touch if youre removing a working set up... I might find its the ecu yet.
Paypal sent
