carrots 1 Posted April 25, 2013 hi looking for all the fuel pipes around the filter area on a 1990 1.8 kr.they dont need to be great as i only want them as a pattern to try and get some made.mine are on there last legs but i cant take them off because car will be off road Quote Share this post Link to post Share on other sites
bmwcompact 10 Posted April 29, 2013 (edited) Can't help you with originals but.......if you are looking for a solution to crumbling pipes........ make your own using: banjo fitting, conical hose tail fitting, nitrile fuel hose and clips from http://www.advancedfluidsolutions.co.uk. I only made the accumulator to pump hose-it cost me about £11 inc postage. You will struggle to break the connections to the accumulator. On 2l 16v -(1.8 may be different I haven't checked) you need the following: M16 x 1.5mm conical hose tail fitting for 6mm ID hose (accumulator end) M12 banjo with hose tail fitting for 6mm ID hose (pump end: you reuse the hollow pump bolt because it also contains a 1 way valve)) 1/2 Metre nitrile fuel hose 6mm ID and 2 off clips (minimum order length) Edited April 30, 2013 by bmwcompact Quote Share this post Link to post Share on other sites
carrots 1 Posted April 29, 2013 cheers i will look into that,i was just going to take some old pipes to a hydraulic company and get them to make some up Quote Share this post Link to post Share on other sites
