Ben Armstrong 10 Posted April 29, 2013 Hi guys As a newbie to the Corrado family I did look quite hard around for an answer to my problem but am lost now with what to do? I have sealed up my foliage gasket in the scuttle under the bonnet so water can't be getting in there still surely? I've checked my membrane and that's all ok so why is my car so wet at the bulkhead on the inside? Any help would be great, thanks again Ben Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted April 29, 2013 Are you losing coolant? Are your windows steaming up when the heater is on? If so, it's the heater matrix. Best wishes RB Quote Share this post Link to post Share on other sites
Ben Armstrong 10 Posted April 29, 2013 My windows don't steam when the heater is ON no ! When I'm doing 50 mph plus tho there is wind noise from the windscreen on passenger side so does that mean the seal is nakered ? Quote Share this post Link to post Share on other sites
VR6 0 Posted April 29, 2013 Is it water or coolant? Fairly crucial part of the diagnosis. Quote Share this post Link to post Share on other sites
Ben Armstrong 10 Posted April 29, 2013 Water definitely not coolant Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted April 29, 2013 could be the screen if you are getting noise & water in the cabin..... Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted April 29, 2013 Hi guys As a newbie to the Corrado family I did look quite hard around for an answer to my problem but am lost now with what to do? I have sealed up my foliage gasket in the scuttle under the bonnet so water can't be getting in there still surely? I've checked my membrane and that's all ok so why is my car so wet at the bulkhead on the inside? Any help would be great, thanks again Ben have you dried out the sound deadening under the carpet since sealing this up? they soak up alot of water! Quote Share this post Link to post Share on other sites
bully 10 Posted April 29, 2013 i have this issue and its from sunroof seal, if no sunroof seal then cud be door seals... Quote Share this post Link to post Share on other sites
carrots 1 Posted April 29, 2013 have you got the crappy plastic cover over the heater vent under the bonnet Quote Share this post Link to post Share on other sites
burrellp 10 Posted July 2, 2013 I literally just had this problem. There is a drain on the right side of the engine bay, right by the windshield. If ANYTHING gets in there..like a leaf or a piece of grass etc...it fills with water and overflows into an air duct that is sitting in the open. Stick a metal coat hanger through this hole down to below the right front wheel bay and you should be set. Just gotta make sure it stays clear Quote Share this post Link to post Share on other sites
