Viper99
temp at 220!
My temp is skyrocketing up to about 220. My oil has been leaking like mad and i cant find what is leaking. I think my oil return from my charger might be broken but im not sure. The oil spots are near the axle on the catch pan/skidplate area. Please help
if it is a G60 you have nothing to worry about, the temps run really hot on G60s. i would get 220 just from moderate driving. when im driving hard i would get it into the 230s. 220 is nothing to be freaked out by.
my best advice for the leak is to clean all the areas where there is a lot of oil, clean all the tubes where you think you will be leaking from etc. then take if for a drive and see where there is fresh oil. i dont have much experienece with looking for oil leaks on my corrado, but i think this could help.
