G60 CS 0 Posted May 11, 2013 A while ago I fitted a new brake and clutch master cylinders to my 92 G60. , stupidly I didn't do the clutch slave cylinder at the same time !! It started leaking a few days ago wasn't a lot so I ordered a new one but had to use the car a little bit for the be t few days, so long as I kept the fluid topped up I was able to make normal smooth gear changes . Yesterday had to make a coup,e of hard ish clunky changes. I fitted the new slave cylinder and bled the system. I now can only get 2nd, 4th & neutral ?? Checked around the cables and linkage and nothing seemed out of place any ideas ? Do t really have a Luke how to check things like shifter, cables linkage etc Quote Share this post Link to post Share on other sites
G60 CS 0 Posted May 15, 2013 Solved ! Forward backwards shift cable completely seized Quote Share this post Link to post Share on other sites
