Ray1965 10 Posted May 14, 2013 Today my 1995 vr6 corrado, started and the engine ran fine it was then parked up for hour and a half. it started ok but was running on only 4 cylinders, checked the HT leads etc, and they are ok. Number 3 and 4 cylinders are not getting a spark (HT leads and plugs again ok) so does this point to a faulty coil pack? if so weres the best place in the uk to get a repalcement. Also i was thinking if there is anyone in my area (Rotherham South Yorks) if they had a spare pack i could try? as i have picked up in a post on the forum sounds like a good idea, to deffo determine if it is the coil pack at fault. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted May 14, 2013 Definitely sounds like it. You can try spraying a fine water mist over the coilpack in the dark - sparking indicates definite failure, but no sparking doesn't mean it's ok... GSF sold me one for £90ish last time I was struggling with one. Ended up fitting my spare instead (after covering it in epoxy) and they gave me a full refund when I took it back, so maybe go buy one and take it back if it doesn't fix it? I'm quite confident it will though ;) Stone Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 14, 2013 YES sorted! Bought a replacement from GSF, after the coil pack was removed and found a 2cm crack in the body and it had rusty water stains on the joint between the bakerlight and the heat sink. Replacement was a Beru make same as what i took off price was £140. Just glad it is back on all 6 pots now. Quote Share this post Link to post Share on other sites
