neuon2003
Rear axle spring clips
Looking for a pair of these for refurbishing. It is a spring clip with a captive nut for the rear shock absorber lower bolt. The clip sits inside the rear axle arm. It's the equivalent of item 4 on the attached (but not just a loose nut).
[ATTACH=CONFIG]74173[/ATTACH]
Just buy new from VW, less than a fiver a pair - you're meant to replace then every time you change shocks and they rot / rust over time.
