Mystic Storm
24v VR6 - Dark Burgundy Pearl for £2600 in Edinburgh
After buying a new Scirocco last year and only putting 500 miles on the Corrado in a year, I’m sorry to say it’s definitely time for her to go. I also feel sad that she lives in the garage most of the time. Someone will love doing the little jobs I keep putting off as the car could easily be brought back to show standard with mimimal effort. She has never let me down and starts/runs like a dream. If I could afford to run both cars I would but I can't justify it any more.
Summary:
* 24V conversion done by PSI in 2005 -http://www.psituning.com/page.php?xPage=corrado24v.html
* Engine 76k miles
* Car 141k miles
* Tax Oct 2013
* MOT May 2014
* Owned since Oct 2007 - done about 23k miles
* Full VW/VW specialist service history
* Original manual/service book and two sets of keys
* Over £9k spent under my ownership with all receipts (see list below)
Good Points:
- Just been MOT'd with no advisory notes and it didn't need much to pass, also just been serviced;
- Always garaged;
- Car has been maintained regardless of cost and is in superb mechanical order;
- Leather interior is in great condition;
- KW V1 Suspension;
- Recently fitted new heater matrix and radiator;
- Engine work done in diagnosing slight misfire;
- Spare rear lights (red tinted), de-badged grill and various spare badges.
Bad Points:
- Sunroof only tilts;
- No door lock pins (never replaced them when I changed from de-locked to normal handles);
- Blowers work on all speeds but not every direction (new bowden cables needed);
- Alloys could do with a good clean up after being used the past few winters;
- Paintwork needs touched up in places (typical for age of car).
I've tried to be as realistic as possible with the price of £2600 and think it's a steal at this given how good this car is. All the car needs is a little work done on the exterior and it would be close to perfect again.
I'm open to any sensible offers. Any questions just shout on 07447 600 398 or email me at [email protected].
Cheers,
James
Maintenance List:
05/12/2007 - Star Performance, Kirkcaldy - Oil Change, Oil filter, Coolant Switch - £170.72
30/01/2008 - Star Performance, Kirkcaldy - Front Wishbone Bushes, Rear Bumpstops, Wheel Alignment - £279.15
19/04/2008 - A&J Motors, Edinburgh - Rack End Replaced, Rear Breaks stripped & cleaned - £366.41
14/08/2008 - A&J Motors, Edinburgh - Oil Change, Oil filter - £98.39
21/08/2008 - Family Garage (free labour) - Fuel tank refurbed and fitted - £60.00
11/09/2008 - W.A. Barclay, Wigtown - Checked ABS fault (NSF sensor), Wheel Balancing - £48.18
12/05/2009 - W.A. Barclay, Wigtown - NSF Hub and Wheel Bearing, NSF ABS Sensor, Wheel Balancing - £276.28
17/06/2009 - A&J Motors, Edinburgh - Re-fitted Door Locks, Checked ABS fault (Modulator Unit) - £103.50
20/08/2009 - ATS Euromaster, Castle Douglas - New tyre valves, Tyres refitted and balanced, Wheel Alignment - £70.95
21/08/2009 - A&J Motors, Edinburgh - Oil filter, Oil Change, Sparkplugs (x6), Sump plug - £205.79
14/10/2009 - A&J Motors, Edinburgh - Front & Rear discs and pads, Front & Rear wheel bearings, OSF ABS Sensor, ABS Rotor - £591.41
18/12/2009 - A&J Motors, Edinburgh - Coil Pack - £87.29
01/02/2010 - A&J Motors, Edinburgh - Coil Pack - £91.27
14/05/2010 - A&J Motors, Edinburgh - Oil filter, Oil Change, Sparkplugs (x6), Coil Pack, Sump plug, Gearbox mounting, Front wiper blades, KW V1 Suspension - £1521.01
06/10/2010 - PSI Tuning, Newcastle Under Lyme - Rad switch and diagnostics - £161.81
17/01/2011 - McConecheys - 4 x Goodyear Eagle Tyres - £300.00
02/03/2011 - A&J Motors, Edinburgh - Sparkplugs (x6), Oil Change, Oil filter, Fuel filter, Front Lens - £294.74
27/04/2011 - A&J Motors, Edinburgh - Fuel Pump, Secondary Air Relay, Diagnostics and fuel/electric checks - £613.48
09/11/2011 - A&J Motors, Edinburgh - Diagnostics for minor mis-fire, Rocker cover, Cylinder head gasket, Valve stem oil seals, Radiator, Manifold Gasket, Sparkplugs (x6), Heater Matrix - £3048.84
08/05/2012 - Jack Walker Partnership, Edinburgh - Oil filter, Sump plug, Engine flush, Fuel filter, Brake pipes & fluid, Anti rollbar droplink, Rear wiper - £408.53
27/04/2013 - Euro Carparts - Exide Premium Battery - £79.20
10/05/2013 - Jack Walker Partnership, Edinburgh - Oil filter, Sump plug, Engine flush, Tyre bead resealed, Brake pipe coating - £213.60
Edited by Mystic Storm
Updated description
