Sheriff Jeff McQueef
Tracking values for 35mm lowered rado vr
No reason why you shouldn't use the conventional numbers for tracking and camber. 205's a standard tyre width, so the only potential issue is arch/tread clearance needing more -ve camber due to the spacers.
At "only" 35mm lower, I'd be looking to roll arches (or use smaller spacers) rather than introduce out-of-tolerance camber if there's an issue with arch/tread.
