Benjevw
Vr6 distributor removal
Hi guys
How do you remove a distributor?
I've undone the two hex bolts but doesn't seem to want to come off !
I've tryed pulling it and levering it off but I don't want to force it.
Cheers
Ben
have you taken the cam cover off, from memory you need to as the distributor drive shaft has a shoulder on it.
I remember a few months back helping a m8 swap his over to my old one, had the same problem but it either just pulled out or twisted out? cant quite remember but we deffo didn't remove the cam cover or inlet manifold or anything like that, getting it back in how ever it needs to locate on a lug i think and only goes on one way , sorry I cant be of anymore use , hopefully someone will clarify
I haven't tryed it with it off yet but I'm at a point where I can so ill try that :) cheers
---------- Post added at 10:39 PM ---------- Previous post was at 10:33 PM ----------
I've only really tried pulling, did twist it a little but didnt feel like it wanted to go..
Cheers for the advice mate
Much appreciated :)
Cheers
its a couple of years ago but i definitely had resistance and didn't want to force it, swear blind there's something that prevents its removal either within the chain cover/ or head.
similar problem/ thread here http://the-corrado.net/showthread.php?t=31881
Sweet!! Cheers aide:)
ill pop that off tomorrow and start taking the chains off :)
Mine certainly goes off and on with everything else still in place, even the valve cover. It should be tight though; there's an o-ring around the body that keeps it snug.
Hi guys
Turns out there is just an o-ring keeping it snug in the timing cover.
No need to remove the rocker, well not on my 93' VR anyway
Cheers
Ben
