Twiss
alternative aux pulley setup issue
Hi All
Im in the middle of changing over the alternator setup on my corrado 16v it has a 6a engine block, I have the water pump and the alternator from a mk3 8v golf so it uses the ribbed belt setup but I I am having trouble finding an ABF Crank pulley.
I have found some info that maybe a ABA crank could fit if it is machined down or a 1.8T Crank pulley could fit if I can put a 6mm shim between it and the crank..
Does any one confirm this or even better show me some pics?
or even have a ABF crank pulley for sale .
Thanks Vaughn
Ok so I have found that a Aba Crank from an Mk 3 8v can fit a 16v if it is machined down by 5.8mm and a new center ring pressed in to help center it on the crank bolt.
Can anyone recommend a machine shop that could do this for me ?
