chopper666 10 Posted July 10, 2013 Hi I took my 93 vr6 too get plugged into vagcom yesterday and we could talk too the engine no problems but when trying too talk too the abs system we had no joy . I got told it could.possibly be a abs pump itself what. Has gone or the ecu.has anyone any idears on the solution as it needs mot next month but wont pass due too abs light staying on Quote Share this post Link to post Share on other sites
chopper666 10 Posted July 10, 2013 Could also anyone tell me if part number 358614117 abs pump will fit the vr6 as. Mine is part number 358614217 which I believe is off a mk3 golf vr6 Quote Share this post Link to post Share on other sites
mr.ots 10 Posted July 10, 2013 Hi I took my 93 vr6 too get plugged into vagcom yesterday and we could talk too the engine no problems but when trying too talk too the abs system we had no joy . I got told it could.possibly be a abs pump itself what. Has gone or the ecu.has anyone any idears on the solution as it needs mot next month but wont pass due too abs light staying on To get vagcom to communicate with the ABS ECU you will need to set the latency to 5 for the com port you are using. Go into device manager on your pc and under ports select the port you are using for Vagcom and I think you have to go into advanced settings and change the latency setting to 5. This should cure the problem. ---------- Post added at 10:32 PM ---------- Previous post was at 10:15 PM ---------- Could also anyone tell me if part number 358614117 abs pump will fit the vr6 as. Mine is part number 358614217 which I believe is off a mk3 golf vr6 Yes the 358614217 part is from a golf and isn't interchangeable with the Corrado. Quote Share this post Link to post Share on other sites
