tessorodesoto
what is this?
Hi, this is a 1990 g60. I was driving this morning and suddenly started to see water vapor smoke coming from under the hood. There was high pressure coolant coming out of a small cylinder with 4 wires on top right next to the battery facing the front grill, on the side of the radiator) I could hear a pssssssss sound as if high pressure was being released from there. Thanks for your help. ( sorry im not being able to attach a picture(
Not sure about a g60 as I have a Vr but it sounds like pressure escaping from one of the temp senders that are in the block . If it is it's no problem , it's only a rubber 'o' ring that's given out . Sure some of the g guys will put you right if I'm wrong
Rob
