Blown 0 Posted May 13, 2004 Thick as two very short bits of 2x4 I am.... Got an rsr outlet and Rallye intercooler today that I bought from LowG(who gave a first class service, :thumbleft: thanks m8!) but I'm not sure how to fit the rsr. I know it's fitted to the charger somehow,but I can't figure out where. Is it a case of removing the black plastic box-and junking it- from the rear of the charger and fitting it there,or is it fitted elsewhere? Pics would be appreciated. Quote Share this post Link to post Share on other sites
mark28G60 0 Posted May 13, 2004 You need to remove the black box on the side of the charger which is the silencer and then the rsr outlet bolts straight on instead, could get some pics on sat if you want let me know? Thx Mark :evil: Quote Share this post Link to post Share on other sites
Banana Man 0 Posted May 13, 2004 isn't the kit migs sent you the 180 degree bend rather than the rsr I would hope it is as you would need a 180 deg samco if it's a rsr outlet but yeah you need to remove the black silencer box and bolt the 180 to the outlet port of the charger casing :) easy enough! Quote Share this post Link to post Share on other sites
