Stonejag
VR6 injector o-ring replacement
Hi all,
I'm rebuilding my spare fuel rail as part of my continuing head rebuild. Has anybody replaced the o-rings on their injectors, and if so what did you use? The existing ones don't look too bad but I'd like to shotgun the lot as it's annoying to have to take it all apart again after you've done a big job..!
Thanks
Stone
I bought a full set online. Then when I got them refurbed they replaced them all anyway.
Yours for £6 posted if you like?
Done, thanks chap! :)
In the interests of being helpful, I did a bit of my own digging - the seals are part number 035906149A (a 7.52/3.53mm Viton O-ring) which are available here at £6.06 for ten. Bargain compared to VW's £3 each!
Stone
