beastie4126
1996 (N Reg) Blackberry Corrado VR6 ** Sold **
Located in Leighton Buzzard LU7 - Bedfordshire
For Sale: £2900,
*** Car is on the standard Speedlines and not the BBS wheels shown ***
MOT Expires = April 2014.
Six Months Tax just put on the car.
VW service history up to 89000 Miles
Current Mileage= 104033 (may increase but not by much)
Owner’s manual and documentation from when 1st delivered.
MOT’s since 1999 (basically all of the cars life)
Various receipts for work completed and items installed on vehicle.
Full Cat 1 Cobra Thatcham approved alarm/immobiliser installed only a few months ago with certificate of installation
I have owned this car since 2009 and in that time I have covered less than 10,000 miles. Unfortunately as life, work and all the parts in-between seem to have taken over my life at the moment this car is not being used as it should and I don’t want to see it sitting on the driveway when it should be being used in anger.
Good Stuff:
• Schimmel 263 Cams fitted at 100,000
• Schimmel Performance Valve Springs
• Schimmel Lightweight Valve retainers and valve cotters
• Light weight pulleys (water pump, alternator and power steering)
• Miltek Stainless exhaust
• Samco Coolant Hoses
• Mocal Oil Cooler & Thermostatic sandwich plate
• Gruven Rad elbow
• New Radiator
• D & G Radiator mount with 12’ & 9 ‘ Fans
• Ceramic coated 6-2-1 Exhaust manifold
• Magnecor 8mm HT leads
• Vibratec front & rear mounts
• VF Gearbox Mount
• Ground Control Camber plates (http://www.ground-control-store.com/products/description.php/II=727)
• SWG scuttle cover
• GAZ GHA adjustable Coilovers
• 288mm front brake conversion
• Mk4 rear brake caliper conversion
• Goodridge hoses throughout
• Front Neuspeed 25mm Anti Roll Bar
• Rear Eibach 25mm Anti Roll Bar
• DDI Gauges
• Sony Bluetooth Stereo and new speakers throughout
• Black heated Leather interior
• All Electrics work including the sunroof and spoiler (mirror switch is sticky but I have a spare)
Minor engine rebuild at 100,000 miles due to head gasket failure with the following parts replaced/ refurbed:
• Head Skimmed and checked
• Valve Seats recut
• Chains and Guides
• Water pump
• Crackpipe, Thermostat housing and stat
• MK4 High Comp head gasket
• Valve guides & Seals
• Sachs Performance Clutch
• New expansion tank
• Coolant & Oil inc Filter
• Other assorted gaskets and seals
• New PCV
• Front cross member, sub frame etc rust treated and painted
Parts replaced within the last 4000 miles:
• Rear discs & pads – This year
• Rear bearings – This year
• Front discs and pads
• Aux tensioner and belt
• Rear top mounts
• Front suspension arm bush’s (R32 rear)
• Rear Beam bush – Powerflex
• Battery – This year
• Wipers
• Sunroof seal
• Plugs
• Drivers front wheel bearing
• Front Grill & VW badge
• Drivers Door seal
• Rear VW badge
• Ariel Seal
• Beru Coil pack (heat shielded)
Bad Bits:
• Occasional ABS warning light but VAGCOM reports it as the traction control valve. I have 2 spare ABS pumps that I will give to the buyer.
• Bonnet and wings have motorway induced stone chips in the paintwork. This car used to travel back and forth to Edinburgh every week.
• Two small dents on top of bonnet and one underneath and age related body work scratches.
• Small piece of rust the size of a 20p on the passenger door
• Scuff on rear bumper
• Scratch on rear panel near boot lid which has been touched up
PM me for further info.
Edited by beastie4126
