brettski
Fitting a four branch on a 16v corrado help!
Can anyone help or guide me in the correct direction I have bought a Milltec manifold and I am not sure if I have got to drop the subframe to fit it or if its possible to do it without any help would be most gratefull thanks in advance Brett
You should be able to manoeuvre it out without removing the subframe, but you'll need to do most from underneath. It can be done without, but I'd seriously suggest getting it on a ramp for ease of access mate. Fitting should be very easy, its just removing the studs from the old one that'll cause you serious buggerance!
