DiamondTony 10 Posted September 7, 2013 Hi all, I am doing a 20VT conversion on my 1991 (H plate) 16V Corrado. I've been reading up on it and basically my rev counter runs from the dizzy so if I drop the engine in now the rev counter will not work... I need to buy a tachometer adapter to convert the signal form analogue to digital. Has anyone done this before? And what Tachometer is the best to use? I have found this one on a US site - will it work? Looking to have the conversion done by end September :) http://msdignition.shptron.com/p/tach-adapter Thanks!!! Quote Share this post Link to post Share on other sites
GrahamU 6 Posted September 7, 2013 What ECU you going to use, the late cluster works with the OEM ECU Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 7, 2013 What ECU you going to use, the late cluster works with the OEM ECU It's the standard ECU from the engine, AUM Audi A3 150 engine - been remapped already - and my Rado is an early model so will need the adapter :( Quote Share this post Link to post Share on other sites
GrahamU 6 Posted September 7, 2013 Change the cluster, its easy and will cost a lot less there's a full write up on vortex on how to change it You'll also need the electronic feed for a speedo to go into the ECU so if you change the cluster you will have the electronic speedo aswell Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 7, 2013 Can I find a 16v cluster with the digital feed? That tacho in the link is only $50... I'm fairly new to Corrado's and I'll only be "helping" with the conversion lol Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 7, 2013 These the instruments you mean in the other thread mate? 2 indicator lights? The wiring loom different then? http://www.ebay.co.uk/itm/Volkswagen-Corrado-16V-Speedo-clocks-instruments-VGC-/370893032592?pt=UK_Motorcycle_Parts_13&hash=item565af28c90 Quote Share this post Link to post Share on other sites
GrahamU 6 Posted September 7, 2013 looks good Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 7, 2013 cool, I'll try sort it out when I get back from my hols :thumbleft: Quote Share this post Link to post Share on other sites
