VW_chris
Corrado`s broke, Help! / WANTED
yo,
today my driveshaft decided it wanted to snap inside the hub, lost a centre cap, the hub nut and part of the splined shaft.
this has broke the wheel bearing and no doubt the drive flange, its caned the brake disc and carrier (288mm upgraded) has been cut into by said disc (can get one no sweat).
what i need to know is are theese corrado only parts OR can i use parts off other models?
ALSO heres the list of parts i need so far,if anyone on here has what i need in good condition, get in touch!
- N/S Corrado VR6 Drive shaft + Hubnut
- N/S Corrado VR6 Hub assembly (pref with good bearing)
- N/S Corrado VR6 Track Rod End
- 2 x Speedline Centre Caps
Any help with this would be greatly appriciated, im copying it into the wanted section also
CHEERS CHRIS!
