fry
polishing the inlet manifold
Just prchased a 50 mm inlet manifold thinking of polishing it to make it look nice!!! Anyone got any tips for D.I.Y ? (by that i mean tools etc) or is it less hassle to get it done by a pro..???
cheers
It's a time consuming job. First thing to do is get it bead blasted (not sand!!) professionally and then you need to sand the main tubes down with varying grades of wet and dry. Then you need to do the intricate areas with a dremel.
Personally, I'd get it powder coated as once polished, you need to buff it regularly unless you coat with some heat proof clear laquer.
Kev
Cheers for the reply.. After all that I think I may just give it a real good clean then fit it !!! I cant be arsed with all the polishing, its enough having to do the car !! :?
