n3p
Brake Fluid
Quick Q - Got some 323mm calipers to go on, and I also have horse loads of VW DOT4 left over from when the ABS pump was replaced. I know DOT5.1 has a higher boiling point than DOT4, but as I won't really be tracking the car will the VW DOT4 suffice?
Also, I'm a lazy bugger and keeping DOT4 would make the caliper swap a bit easier.
Thanks in advance
