yellowG 0 Posted November 19, 2013 (edited) http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=301019752067 Edited November 19, 2013 by yellowG Quote Share this post Link to post Share on other sites
bendunstan 10 Posted November 21, 2013 The listing says its for the outlet only, i assume that means you dont get the silicone pipe, jubilee clips, o-ring for between the charger and outlet or the sleeve to join to intercooler pipe? Also there is no pic of the bolt that holds it onto the charger, can i assume this doesnt come with either? Quote Share this post Link to post Share on other sites
yellowG 0 Posted November 22, 2013 You assume correctly, the auction is for the outlet only, the bolt that holds your baffle box (if your still running one on your car) to your charger is the same you can also use the o ring baffle box to charger gasket, you would just need a reducer and joiner and jubilee clips, thanks.... Quote Share this post Link to post Share on other sites
