benmuir
Mercedes CLK 2003 PX/SWAP Corrado
Hi,
Looking to swap/px or sell my Mercedes CLK 320 2003, all details and pics in Gumtree link below, in addition I have included the service history etc. I am looking to own a VR6/G60 and would be content to swap or PX.
Many Thanks
http://www.gumtree.com/p/cars-vans-motorbikes/mercedes-clk-320-swap-px/1040857664
I have full service history on the car amounting to over 5K, all stamps are in service book with all receipts and bills in an annotated A4 folder (can email on request) Car registered 30/09/2003 at Mercedes Benz-Whitfield Ltd (Dealer No 181)
Previous owners: 5 (HPI Clear, report available)
MOT: 30 Nov 14
Tax: 30 May 14
Service Details:
01/11/13 Lower Front Control arm replaced (advisory at MOT) + MOT £208
06/09/13 Rear Diff oil changed
04/06/13 New Headlight Washer pump fitted £23.00
25/04/13 Car fully clayed and polished Brake callipers front and rear primed and sprayed Brakes fully bled using Ezzibleed system
14/04/13 Brake fluid £8.90 To conduct brake flush
14/04/13 Mercedes centre caps £18.97 Replace current worn ones
14/04/13 Tax disc holder £9.99 Old one perished
14/04/13 New wipers £22.95 Current wipers extremely noisy
Car purchased by Craig Campbell 12/04/13
21/11/12 Hunslet MOT Centre £216.18 Receipt for: Rear Brake shoes, front to rear brake pipes renewed and bleed
01/10/12 Motosave £14.99 Receipt for: Tracking
20/07/12 AutoGlass Free Windscreen chip repaired
19/07/12 Hunslet MOT Centre £176 Receipt for: Front drop links, NSF lower wishbone arm, door lubrication
13/07/12 Mercedes Key £227 To have as a spare, as only 1 came with car
18/05/12 MJ Tyres £246.16 Receipt for: 2 x Pirelli front tyres 225/40/18
03/05/12 Bankside Garage £204.48 Stamp in service book + receipt. Oil/Air/Fuel/ filter service + exhaust bracket welded (cause of rattle)
06/11/10 Spring Court Autos £152.47 Stamp in service book + receipt. Oil/Air filter service
10/09/09 Spring Court Autos £497.22 Stamp in service book + receipt. Oil/Air/Charcoal filter service + NSF wheel bearing and 1 x front tyre
18/11/08 Greenvale Services £498.68 Stamp in service book + receipt. Oil/Air/Pollen/ filter service (including ATF/antifreeze top up) + 2 x number plates, OSF coil spring and ECU reset.
05/03/08 Greenvale Services £381.60 Stamp in service book + receipt. Oil/Air/Pollen/ filter service (including ATF/antifreeze top up) + 2 x wipers.
07/06/07 Greenvale Services £826.69 Stamp in service book + receipt. Oil/Air/Pollen filter service (including ATF top up) + plugs, NSF coil spring, front discs, front/rear pads and ECU reset.
18/10/06 Greenvale Services £474.17 Stamp in service book + receipt. Oil/Air/Pollen filter service (including ATF top up) + 2 x front tie rods, tracking and ECU reset. *MOT conducted*
20/01/06 Greenvale Services £375.44 Stamp in service book + receipt. Oil/Air/Pollen filter service + front brake pads and ECU reset
20/05/05 Greenvale Services £348.56 Stamp in service book + receipt. Oil/Air/Pollen filter service + rear brake pads and ECU reset
23/09/04 Greenvale Services £207.99 Stamp in service book + receipt. Oil/Air filter service (including ATF top up)
Features:
Auto Xenon headlamps
Seatbelt presenters, no leaning back for the seatbelt,
5 speed automatic gearbox with sports and comfort mode,
Black leather interior,
Silver metallic bodywork,
Dual climate control with freezer cold air conditioning, recirculate, charcoal filter system and fully automatic setting,
2 stage heated and fully electric moveable front seats with 3 position memory,
Electronic moveable tilt and reach steering wheel with easy exit function,
Front headrest drop when the front seats are put forward for extra entrance room,
4X electric, fronts have 1 touch,
Rear windows have child lock controlled from the front,
Full tool kit,
Extra capacity battery,
Front armrest contains Ipod connected to Aux in Glovebox (telephone cradle removed, however available)
Full first aid kit(unused),
2X full rear seat belts,
Heated screen wash system,
Reclining rear head rests,
Remote central locking,
Remote boot opening from the key,
Full closure or full opening (windows and doors) from the programmable key,
Infra-red type key, x 2
Switch to turn off ESP/traction,
BAS - Brake Assist Plus, a second brake servo kicks in to really slow you down,
ESP - Electronic Stability Programme, an on board computer monitors each wheel and stops you spinning and sliding,
ABS - Anti-lock Braking System,
FSH – All bills and stamps to confirm
245/35/R18 rear
225/40/R18 front nearly new Pirelli Potenza tyres,
Button to lock/unlock all doors,
Anti-jacking system, car automatically locks at over 10MPH,
Cruise control with speed limiter,
COMAND, (Cockpit Management and Data system)
Radio volume increases with speed,
Elegance spec with burr walnut, including optional steering wheel
Factory fitted 18 AMG wheels,
Rear occupants have separate air conditioning/heating outlets,
3 speed rain sensitive single arm wiper,
Light sensitive dash console when the external lights are on,
Electric moveable, folding auto heated mirrors with indicators in them,
Near side mirror automatically adjusts so you can see the kerb in reverse,
All mirrors are auto dimming,
Parking sensors front and rear, come on automatically over 10MPH and in reverse, button to override,
Lockable glove box,
Locking wheels nuts,
High level brake light,
Heated rear screen
High pressure headlamp washing system,
Headlamp height adjusters,
Front and rear fog lights,
Rear centre armrest contains cup holders and first aid kit,
Front seats have map stowage in the back of them,
Front passenger footwell has elasticated expanding item stowage,
Car has Mercedes Vario service, you only service it when it needs it,
On board computer tells you all faults and when to service, MPG and a million other things, the book for it is like war and peace,
Left and right parking lights,
6 Airbags
Variable rev limiter depending on temperature, helps to preserve engine life,
Factory Immobiliser,
Safety belt pre-tensioners,
Anti-theft tow away protection.
Honest Negatives:
I do not have CD for Sat Nav, therefore Sat Nav not working
Drivers mirror glass has discoloured
Chip on rear side window
Chip on windscreen
