4051jon 10 Posted December 29, 2013 Hi guys, I am looking for some advice regarding my not so healthy corrado. Up till a week ago the car was running fine but when i put some fuel in as the car was running on empty, it started running ropey almost like a misfire. I had a roadside recovery man turn up to help and he took off the distributor cap and found that needed replacing along with the rotar arm. I changed both but now the car won't start. Im hoping i have put the leads onto the right sections as i feel i have made a mistake. Can someone tell the firing sequence so i know where each lead goes on the distributor cap and could the fuel filter be a problem. Thanks Guys. Quote Share this post Link to post Share on other sites
jamesoff 10 Posted December 30, 2013 When I was fiddling with the dizzy while trying to fix something here's what I scribbled down on my phone; taking cylinder 1 to be the leftmost (viewed from the front) and the positions on the dizzy as viewed from the side (i.e. the top of the cap): 1 goes to top left 2 goes to top right 3 goes to bottom left 4 goes to bottom rear I've also got a pic which happens to show the arrangement here: https://dl.dropboxusercontent.com/u/12605238/Photo%2020-06-2013%2015%2008%2042.jpg Hope that helps! Quote Share this post Link to post Share on other sites
4051jon 10 Posted January 1, 2014 Hi James, Thanks for replying back to me. I will use the information you have given and hopefully that might be the answer. Don't mind me asking what model was your Corrado? Quote Share this post Link to post Share on other sites
jamesoff 10 Posted January 1, 2014 16v 1.8, KR engine Quote Share this post Link to post Share on other sites
