carrots
age of a 20v engine
hi i am buying parts for my 20v engine ready for the conversion,ive been looking at cambelt kits.problem ive got is the belt kits are different part numbers depending on chassis number which i dont have.any ideas how i can tell its age, its an agu engine .after 2000 there must be something different
This is about the Audi A3, but as far as Im aware, the VAG group shared the engines...
Petrol engines
Name Type Engine code Output@rpm Torque@rpm 0–100 km/h,s Top speed Years
1.6 8v 1,595 cc (97 cu in) I4 AEH/AKL/APF 101 PS (74 kW; 100 hp) @5600 rpm 145 N·m (107 lb·ft) @3800 rpm 11.0 s 188 km/h (117 mph) 1996–2000
1.6 8v 1,595 cc (97 cu in) I4 AVU/BFQ 102 PS (75 kW; 101 hp) @5600 rpm 148 N·m (109 lb·ft) @3800 rpm 10.9 s 189 km/h (117 mph) 2000–2003
1.8 20v 1,781 cc (109 cu in) I4 AGN/APG 125 PS (92 kW; 123 hp) @6000 170 N·m (125 lb·ft) @4200 9.6 s 202 km/h (126 mph) 1996–2003
1.8 20vT 1,781 cc (109 cu in) I4 turbo AGU/ARZ/ARX/AUM 150 PS (110 kW; 148 hp) @5700 210 N·m (155 lb·ft) @1750–4600 8.2 s 217 km/h (135 mph) 1996–2003
1.8 20vT 1,781 cc (109 cu in) I4 turbo AJQ/APP/ARY/AUQ 180 PS (132 kW; 178 hp) @5500 235 N·m (173 lb·ft) @1950–5000 7.5 s 228 km/h (142 mph) 1999–2003
1.8 20vT (S3) 1,781 cc (109 cu in) I4 turbo APY, AMK 210 PS (154 kW; 207 hp) @5800 270 N·m (199 lb·ft) @2100 6.8 s 238 km/h (148 mph) 1999–2001
1.8 20vT (S3) 1,781 cc (109 cu in) I4 turbo BAM 225 PS (165 kW; 222 hp) @5900 280 N·m (207 lb·ft) @2200 6.6 s 243 km/h (151 mph) 2001–2003
thanks but i still dont no if my engine is a 1996-2000 or a 2000-2003.i think it could be the early one tho as the coil packs are screwed down
