agb1980 10 Posted January 7, 2014 Hi, looking for ABS pump part number 1H2 614 217A, anyone got one? Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted January 7, 2014 For what model? Quote Share this post Link to post Share on other sites
agb1980 10 Posted January 7, 2014 For what model? 95 vr6 Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 8, 2014 I have one suitable for a 95 VR6. Bought off a fellow forum member in unknown condition. You are welcome to it as I ended up buying a known working item for a few more pounds. £35 delivered. Quote Share this post Link to post Share on other sites
agb1980 10 Posted January 8, 2014 I have one suitable for a 95 VR6. Bought off a fellow forum member in unknown condition. You are welcome to it as I ended up buying a known working item for a few more pounds. £35 delivered. Great thanks, is this the whole unit with valve block and part number 1H2 614 217A? Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 8, 2014 Complete unit with valve block. Confident it'll bare the 1H2 614 217 A part number. However if not it will definitely fit a 95 VR as it was identical to the one I pulled off my car (95 VR) and the one I replaced it with. Can confirm later if required...? But will fit. Quote Share this post Link to post Share on other sites
agb1980 10 Posted January 8, 2014 Complete unit with valve block. Confident it'll bare the 1H2 614 217 A part number. However if not it will definitely fit a 95 VR as it was identical to the one I pulled off my car (95 VR) and the one I replaced it with. Can confirm later if required...? But will fit. If you could check and let me know that'd be good. Could u send a pic too? Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 8, 2014 Yep. Will do both. Be in touch later today. Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 8, 2014 Pics as promised. Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 8, 2014 Same part, just earlier part designation. *** 614 217 Quote Share this post Link to post Share on other sites
agb1980 10 Posted January 9, 2014 Same part, just earlier part designation. *** 614 217 Hi fella, thanks for checking - i've found one with the same part number as mine now Quote Share this post Link to post Share on other sites
StueyB 0 Posted January 9, 2014 Ok no worries. This is technically the same, pretty sure the 1H2 is a revision number. Quote Share this post Link to post Share on other sites
