VR6 Gar
Trek Session 10 DH bike.
Decided to put this up for sale due to lack of use.
£1200
Fantastic piece of kit, 10 inches of rear wheel travel and 8 up front.
Pretty indestructible frame. Only ever heard of 2 that have been broken and that was in really bad crashes. Try finding another bike this strong.
Frame was recently stripped then resprayed. As such the paint finish has a slight 'texture' from the sandblasting. Should have sanded it down really before spraying. Easy enough to rectify if it bothers you. Painted with Acid Etch 8 then Upol paint, decals applied and finally a good few coats of Upol Lacquer. Hasn't been used since painting it in the summer.
The frame also has a Gopro mount attached by the bottom bracket.
New main bearing were used on the pivot. The smaller bearings on the linkage were in good condition so re used.
Spec.
Small Trek Session 10 with Revox shock with Titanium spring. I am about 5'10" and it was fine for me.
Offset shock bushes and Works Component Angleset. Giving a relaxed 63.5 degree head angle.
Marzocchi 888 RC3 WC forks.
Hope V2 Evo special edition front brake on 225mm disk.
Hope M4 Evo rear brake on Hope floating saw disc 203mm. Both brakes are brand new other than bedding in on the road.
Hope rear hub. Cant remember the model of it or the rim make.
Sun front rim on what I guess is a Kona hub. Came on my old Kona Stinky.
Maxxis Minion tyres. 2.5". Rear is brand new front has plenty of tread.
Danger boy stem.
DaBomb Apache 750mm bars.
Steve Peat signature grips.
Hope bar end plugs.
Bontrager seat post.
Hope seat post clamp.
New Nukeproof saddle.
Truative Cranks and BB which has only seen 5 days use in the Alps.
Middleburn front ring.
FSA bash guard.
Straitline Platform pedals.
XT rear mech with Red anodised Jockey wheels.
Home made rear mud guard.
All in all a very well spec'd bike that will handle anything that can be thrown at it.
Cash on collection from Exeter.
Edited by VR6 Gar
