olly elworthy
supercharger seal grease
when i had my charger rebuilt it was covered internally in some greasy coating that i believe is to increace the sealing effect of the apex seals, ive done a few thousand miles now, and when i had the airbox off to change my belt tensioners at the weekend i noticed the inside of the charger was sparkling clean and dry, no grease to be seen, is there anyway to re apply grease/ lubricant short of splitting the charger and recoating it all manually? a spray perhaps? :?:
This is not something I have come across before. How much is it per can and how often would you suggest applying the stuff. I assume it helps sealing as well as adding lubrication for the apex seals. Is this correct?
