slot
VR6 Oil Temp showing 160c from cold ?? Problem found !
Hi All
I'm just after a bit of advice as to were to turn next ??
Basically my 1995 VR6 MFD is showing 160c on the oil temp even before I turn the key ?
I've done the obvious, new sender checked for trapped wires and even removed and cleaned the multi plug and nothing ? just a continuous reading of 160c :(
Any ideas ?
Thanks in advance
Dave
Edited by slot
Probably got an earth on the sensor wire.
Normally the sensor has a high resistance at room temp (about 4-5 Kohms), as it gets hotter the resistance drops, as yours is showing a high temp the resistance to earth must be low. You have already changed the sensor so my guess is the sensor wire is shorting to earth.
Rog.
Hey Rog
Thanks for the reply pal
Yeah thought this also ?
But after removing and leaving the multiplug disconnected, and turning on the ignition, Im still getting 160c !
It's bloody baffling me (
So if the fault is after the plug ? Does this go directly to the clocks or am I looking at a fault on the ECU ?
Tar Dave
