Grum21 10 Posted March 25, 2014 hi, my master cylinder is shot so been looking for a replacement and like most parts for g60 not easy to find!! My corrado has ABS which just seems make it harder to find, i have searched forums and still havent been able find a straight answer to where i can either get a replacement g60 master cylinder or whether other vag models have a master cylinder that is a direct fit!! Any help with this would be great thanks G! Quote Share this post Link to post Share on other sites
leon263 0 Posted March 25, 2014 Hi mate, I may be able to help you with an ABS master cylinder. I have one which I removed from my 1993, 2 litre MK3 Golf Cabby when I upgraded it to VR6 power, brakes and running gear. The part number on the cylinder is 10.6123-0690.3 and it's an ATE unit. As you can see from the photos below it only has the two outlets for the two lines running to the ABS pump. It was working perfectly when removed. Check the part numbers against the one you have or do a little on-line research and if you think it might do your job, drop me a PM. Quote Share this post Link to post Share on other sites
