Pat.
VR6 02A not selecting 5th. Feels in on tower but is in neutral state!?!
Hi everyone, just had engine out and changed clutch on my corrado. Literally last thing I need to sort is 5th gear. I could get it before but not now!?
I have been trying various alignments using both left/right and front/back adjustment bolts on the tower linkage/ gear stick tension spring.
My problem is this.... I just can't get 5th gear. If I disconnect the cables I can put it into 5th by hand on the tower (lifting up and turning towards the block) it clicks in place as if it's in 5th. However if I start the car and release the clutch nothing happens, as if it's in neutral.
Is there anything internally in the shifter tower that might need adjustment!? HELP! Please
