mmacneill123
Should this be a plastic dummy "valve"?
Hi folks, difficult to describe this without a picture (will try and add picture!!) but the breather pipe on the VR6 left side (where the belts are)that comes out of the metal hood at the top left and goes next to the throttle body (not the breathers on bulkhead side but the ones you see from the front) has an inline valve with a two pin plug on the top.
Only problem is, mine is plastic - just a dummy!! As I am getting a small amount of oil forcing itself out when the engine is cold and dripping on to the hot exhaust and smelling (hopefully that will help pinpoint it too!) I assume it is a valve that is supposed to be open when cold, it would be good to know what it is and should there be a real one there!!
Cheers
Edited by mmacneill123
Extra detail
