p0l1wrath
Vr6 rear engine mount
I'm pretty sure they arent. I changed all three of mine a couple if years ago and I'm sure they were different.
I thought they were the same. I know the inserts that jay sold were the same size. Might be a difference in the housing. Can check my photos tomorrow.
The insert looks the same, but the top and bottom caps are different. I'd assume the inserts are different grade rubber too as the front is supporting more weight than the rear right. There must be a good reason the front is so much more expensive than the rear.
