Atki
Vr6 now back on road
Hi all.
Just to up-date you on the clutch woes of my Vr6. The master cylinder had expired and it subsequently destroyed the release bearing causing the fork to run ( very noisily ) against the driven plate.
Had to do the Gear box off + on on drive. New clutch kit and new master cylinder fitted. Had a brilliant mechanic do the job for me. If you are Norfolk or Suffolk based he is well worth it. VW specialist to boot !!
Huzzah - great when you get them running again aren't they? Who did you use to do the work btw? Where are you (roughly) - I'm out at Reepham :)
