Supercharged
PAS Pipework - replacement options
I have the same problem as My PAS has a slight leak which I cannot trace at the moment. Do you know how many pipes are in the system and whether they are still available. Sorry to partially hijack your thread.
Guy on ebay used to do them, although I think they were just the hybrid brake lines with the correct attaching bits and painted silver.
Reasonable quality I replaced both the 16vG
Yan, thanks yeah I have some of them and they're a good enough match but it's the bigger flexi lines I'm now looking at, the rubber is ok but the ends are in a bit of a state...
VR6 South - basically you have a high and low pressure side, resevoir - pump - rack.
Thanks. Any links to the seller please?
Might be quite expensive, but Pirtek will probably make some up for you on site.
