Andy-H 0 Posted May 3, 2014 Afternoon all, Sorry if this is in the wrong section. My current problem is as follows... As soon as I start my Corrado 16v up the temperature gauge goes up to about 80 degrees. This is within seconds. then it seems to hover around the 110 - 115 degrees whilst driving. I've not checked to see if the gauge does this without turning the engine on yet but wondered if there was a common fault that is easily rectified. Had a quick search and couldn't find a similar problem. Cheers in advance, Andy Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 3, 2014 Almost certain the temp sender needs replacing . I think it's the blue one ? Rob Quote Share this post Link to post Share on other sites
Andy-H 0 Posted May 3, 2014 Cheers Rob, I take it that's the one stuck in the side of the block under the dizzy?? Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 4, 2014 Yes that's the one . May as well change them all while your at it . Rob Quote Share this post Link to post Share on other sites
