AL6
Rear Axle / Subframe Bush replacement
Has anyone any simple method's of replacing the rear axle/subframe bushes on a 91 16valve, is there a simple way of resting it on a jack and removing the bolt and bush without having to drop the whole subframe out? Don't have a ramp handy..
Cheers in advance.
Can be done from underneath but really not a nice job.
Air Chisel makes for an easy life getting the old ones out if you have access to a compressor.
That or make up some kinda of wind in / out clamp type tool to push them out.
In all honesty borrowing a lift for the afternoon will make much lighter work of a difficult job.
