Gti_Jamo
G60 sound at low rpm
Just a wee enqury. Between 1-2000rpm when just cruising my G60 sounds a bit like a subaru boxer engine, it's not misfiring. I do have a little excessive crankcase pressure whick is being dealt with after the summer. Just pushing a wee bit of oil into the intercooler but catch tank getting fitted shortly. The noise sounds good but is it normal due to the charger or possibly related to the above problem or another issue. Everything else is fine with the engine, pulls real good.
Thanks in advance.
Might seem obvious but have you still got the 'snorkel' in the front of the air box?
Light the tube below but in the g60 air box.
[ATTACH=CONFIG]78573[/ATTACH]
Funny you should mention that as i've not put that back on since I changed engines. Seems more apparent from exhaust though. Although only when moving. I have no carpets and a droning front wheel bearing so lots of noise going on.
