unomatt 10 Posted May 11, 2014 Evening all hope you all had a great weekend. I have an issue with my Corrado, the ABS light is permanently on. I am guessing this is a sensor issue. I was wondering, is there a way of finding out which sensor is responsible? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted May 11, 2014 You can do a resistance checks on each sensor. They should be between 1 and 1.3 ohms. If they aren't, the sensor has had it! Unfortunately that won't tell you if there are other faults apart from the sensors. Also, if it is a duff sensor, the fault will remain hard locked on an the light will remain lit for something like 25 or 30 full system starts. Get it scanned with vcds to get the full story. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 12, 2014 Yup. VCDS Scan will tell you which sensor is kaput. Does a bad sensor keep the light on permanently? When I scanned mine 2 weeks ago there were 3 sensor errors, I cleared them and they haven't come back. ABS light was behaving as normal. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted May 12, 2014 Mine stayed on all the time Mike when I had a duff O/S/F sensor? Ian. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 12, 2014 Can't remember the exact fault codes from mine. Just it was 3 corners of the car. Must have been intermittent or out of range faults. Quote Share this post Link to post Share on other sites
