VR-Sixy
Wing Mirror Controller
Does anyone have a wing mirror controller for a '94 VR6? It's the circular bit that fits into the the door grab handle.
The mirrors haven't worked since i took the door card off, my mate at work has checked it all out and there's
power getting to the unit, but nothing is moving.
Ta! :)
If you're feeling competent, the switch comes apart easily and for the sake of a bit of a clean, degrease and removal of the corrosion that builds up on the contacts on the circuit board will normally cure the problem. Just be careful when you pull it apart, there a lots of small tiny parts and springs that can make rebuilding the switch a nuisance.
New switches are approx £70 from VW and obviously have a 2 year warranty.
To remove the switch, remove the trim on the handle itself then remove the 2 screws which hold the handle to the door. The mirror switch is on the back. Remove and fix!
