Micky fletch
Bonnet stay
Hi all
Can anyone tell me the easiest way to remove my bonnet stay .have had a quick look but only bought one pair of hands with me. Which direction do you twist and do you need to push the rubber grommit out first. Would love to get this freshened up and painted
Thanks in advance
You need someone else to hold the bonnet up..
the prop itself if you unclip it and then lean it back toward the windscreen (to the left of the washer bottle), jiggle it and swear at it then it should come out. The rubber grommet thing stays behind.. You need to get it as low down as possible to get it out..
I had a go at removing mine a little while back, & gave up!! It looked to me maybe easier with the battery removed
