owenfishburn
Engine temp and noise
Any help would be great. My vr6 has started to run at a temp of 110 it used to be 90. It doesn't take long to get up to that temp either. When I stop I can smell the heat from the engine bay if that makes sense.
I've also started to hear a noise from the engine when accelerating like a tapping noise which gets faster as I accelerate. I know the clutch release bearing is going as that makes a tapping noise when the clutch isn't pressed in but I'm not sure if the noise is connected in any way. Any ideas
Usually the radiator fan switch causes running at 110c - the first stage fails but check the wiring to it first.
Regarding the noise - what mileage is it on? Have the chains ever been done?
