vw bobby
Wheel Adapters
Hi All,
Just a quick question what size thickness for the adapters will I need to run on my Corrado with my Porsche Wintercults the wheels are 7j x 16" and 8j x 16" with 195/40/16 tyres all round and ET52?
Cheers
Have you bought the one's on ebay? I have a full set of H&R adapter's that would suit these they were used on mine with the 911 C4S cab wheel's I had. Let us know if you are interested.Only thing that may be a stumbling block is the pcd of your car I know it's a 16vt but is it 4x100 or 5x100 if it's 4 then these are no good for you.
4x100 so by that I assume you are still running 16v brake's? Don't take this the wrong way but would you not be better thinking about upgrading the brake's or is that the point in buying the porsche wheel's??
The brakes are g60 brakes with 280mm drilled and grooved discs, but now I have porsche calipers that I will be putting on aswell
