menace2society 0 Posted April 21, 2003 Hi everyone, im considering tinting my windows out black, what is the best and easiest way for me to do this :?: also how much would it cost professionally??? thanks :D Quote Share this post Link to post Share on other sites
G60Jet 1 Posted April 21, 2003 i did mine myself buy film cut to shape on outside of car then inside spray the window with water and washing up liquid, place film on window, trim to size, then add more water/washing up liquid, remove backing and apply using soft rubber of plastic remove bubbles. easy once you get the hand of it really. Pro's charge a lot to do it more or less the same way, but using better film i think Quote Share this post Link to post Share on other sites
LowG 0 Posted April 21, 2003 well i tried to do it on my rear window and i got lots of bubbles,its not easy because its a large area and its not straight,it curves and you will get creasing lines,i think they use a hair dryer to avoid this,the rear quarter side windows are easy as htey small but the rear one is hard,i ended up scraping the whole thing :x its not as easy as it seems as the film is so thin but it can be done if you take time 8) Quote Share this post Link to post Share on other sites
BETTYSWOLLOX 0 Posted April 22, 2003 had mine done lads £220 and it looks the tits, regards BETTY/// :D Quote Share this post Link to post Share on other sites
