Guest sam1990rhodes Posted June 27, 2014 Hi, looking at putting a BAM engine in a late 16valver, need some advice, as the rados used a physical throttle cable and the BAM is DBW, would it be a case of using the accelerator pedal off of a mk4 golf/bora or leon, like this: http://www.ebay.co.uk/itm/VW-Golf-Mk4-Petrol-Accelerator-Throttle-Pedal-Module-1J2-721-503-J-1J2721503J-/321299740762?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4acef4f85a sam. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 27, 2014 Yep and few of us have used those (or the floor mounted pedal) for R32 conversions. Use the exact pedal that the donor car uses to avoid electrical mismatching problems. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 27, 2014 cheers Kevin always a big help :) Quote Share this post Link to post Share on other sites
J.C 10 Posted June 27, 2014 I presume it uses the same system as the 24v, Don't forget to fit a clutch switch and the new brake switch The clutch switch sharpens up the response of the throttle when changing gear (stops the revs froms rising) Quote Share this post Link to post Share on other sites
