jonnyattwood
ABS fault, not the norm! 😔
Alright fellas,
You may have seen my previous post on the obd port not working so I could scan the abs fault, well now I've sort that and it's showing errors I've not got the problem that it's not throwing up any abs faults 😞
It's throwing up a few different codes so I know it's working. Also I had a large water leak from the air intake for the blowers, so I presumed that the abs ecu maybe at fault so I've replaced it with one I know works and still no codes! Has anyone got any ideas what the problem could be?
Thank you in advance for any help
Jonny
