swiftkid 1 Posted July 21, 2014 Hey all, hoping I can pick some brains. I've recently found out my Audi A3 3.2 engine is now an EX engine, it is no more, if I hadn't shoved 12v through it, it would be pushing up the daisies. Anyway, on the search for another engine but just wanting to check which engine I can use. The idea is to swap all sensors from top end over and if necessary the top timing chain cover and run it off A3 ECU which I have de-immobilised now. Does anyone know if this is possible or any hurdles I may encounter Quote Share this post Link to post Share on other sites
clumpy1 11 Posted July 21, 2014 Pm Kev Bacon he's the man regarding R32's Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 22, 2014 I only know so much which I've PM'd Dave :) Vince and Jon at Stealth know a good deal about the electronics side of things but the main differences seem to be the BUB got a different exhaust cam, cam sensors, injectors, ECU, harness etc etc. It was the last of the last R32 engines and a last ditch attempt to refine it a bit I suppose. Prior to the BUB we have a hotch potch mixture of BFH, BHE, BDB, BJS and what not. A mix and match of MK5 and MK4 bits n bobs! Quote Share this post Link to post Share on other sites
