Brunty 10 Posted August 5, 2014 I'll aim to have a proper look at this issue when I get chance, but thought I'd ask here in case anyone has heard of similar. Firstly, a previous owner has bodged the ABS light so that it appears to work (fitted a timer, so the light comes on and then goes off again). My scanner informs me of fault codes for; rear n/s sensor ABS inlet valve front left -N101 Valve 2 for differential lock Supply voltage Now these faults on their own were leading me towards fitting a new ABS pump assy (apart from supply voltage). But last week as I was crawling down a gravelled driveway the ABS sparked up. Thing is, I wasn't pressing the brake pedal - my foot was covering the throttle. A trial press of the brake pedal confirmed that it was working well... So, wiring fault somewhere I presume? Is this a new type of fault?! Quote Share this post Link to post Share on other sites
Brunty 10 Posted August 9, 2014 Well, I managed to get a 2nd hand ABS ecu module. It has cleared a load of faults, so now I'm just left with the N101, ABS inlet valve front left. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted August 9, 2014 Have you changed the brake fluid recently, might be worth flushing the old out and replacing? Ian. Quote Share this post Link to post Share on other sites
Brunty 10 Posted August 9, 2014 Yep, only changed the fluid a couple of months ago. Quote Share this post Link to post Share on other sites
