VEEDUBBED 0 Posted August 16, 2014 Guys, After seeing the strange damage on the inner cv joint cups i'm wanting to uprate the inner cups, possibly one's off a 02M 'box. Will these cups fit into a 02A 'box? Is there a way getting around the fact that the 02M cups bolt into the diff? I've got a Peloquin installed that's 02A and i'd like to keep it. What other kind of mods are involved? Cheers. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 18, 2014 The 02M diff shaft is bigger diameter than the O2A, so I don't think you can use O2M cups. For what it's worth, I used bog standard GKN replacements from GSF / EuroCarParts on my VR6 Turbo years ago and they're still going strong. But if you want mega strong, here are a couple of options: Best and strongest shafts / CVs - http://www.driveshaftshop.com/import-axles/volkswagen GKN do uprated shafts and joints too - http://www.gknservice.com/global/motorsport/cv_shafts_joints.html 1 Quote Share this post Link to post Share on other sites
HummuH 10 Posted August 22, 2014 The 02M diff shaft is bigger diameter than the O2A, so I don't think you can use O2M cups. For what it's worth, I used bog standard GKN replacements from GSF / EuroCarParts on my VR6 Turbo years ago and they're still going strong. But if you want mega strong, here are a couple of options: Best and strongest shafts / CVs - http://www.driveshaftshop.com/import-axles/volkswagen GKN do uprated shafts and joints too - http://www.gknservice.com/global/motorsport/cv_shafts_joints.html Very useful info mate. FWIW, I run the OEM GKN CV's and drive shafts on my 20VT running fairly big power and torque and, touch wood, to date they have stood up fine. Quote Share this post Link to post Share on other sites
